I have recently installed the latest patch, and just now tried the conforming hair. I loaded the P4 nude woman, added the long conforming curls and conformed to the woman, and they worked correctly. I then added the leotard and conformed that, too. It seemed to work, also. And, a tip until the final version is out, back up your original Poser.exe, Poser.rsr, and asi32_12.dll files. The patch is being distributed as an EXE for PC, and it won't patch the patches. You need to have the original above three files in place for the patch to run.
Even with the newer patch loaded I cannot open a previously saved P4 file (pre any patch)and have the tennis shoes conformed to the feet of a P4 female character. One shoe goes approximately in the middle of the back and the other covers her groin region. If I try to restore element or re conform the shoes nothing good happens. Anyone else confirm this?
Somebody tell me when this is all over and I can just download something that fixes things rather than adds new problems. :)
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
We can all understand your frustration but, since Meta blew us off, Larry W. is doing the work on his own. As such, he needs users to test it and help him find the bugs or we will never get a bug-free patch. Discussing it here helps to determine if problems are, in fact, actual bugs or arise from some other cause.
Any problems with the new patch? In the previous patch, you could delete the Ground. :/ That was a shock. Also does the latest patch fix the following problem? If you turn the Ground, say, 30 degrees and then scale the X dimension, you don't get a rectangle turned 30 degrees; you get a rhombus. Weird. This is a pre-patch problem. At least for me. Mike Sentence fragments. Gotta love 'em.
