Thu, Nov 14, 8:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Tailor Problem / Query
FLTigger ( ) posted Tue, 23 April 2002 at 2:01 PM ยท edited Tue, 05 November 2024 at 1:19 PM
Just purchased Tailor and have tried to conform Daz's Victoria's Changing Fantasy Suit (1), to the Asia Character available here in the Marketplace. If I am reading the tutorials correctly do I have to create the morphs on the dress for the body morphs one at a time? By that I mean in Tailor do I select for example 'pbmBarbarian' on the Asia character then right click to 'Select all morphs with this name', then select 'Morphs selected are like one body morph', then select 'Create morphs in the dress'. What if I need to also change 'pbmSuperHeroine' and a few others ?? Do I do them all individually .. all at once, dont quite understand the workflow for this. I set up the 'pbmBarbarian', then went into Poser having saved the 'dress', set up the Full Body Morph. If I go back to The Tailor there is no way of easily clearing all of the check boxes for 'pbmBarbarian' without manually doing it myself. This is of course assuming I have to do this cycle for each morph I need .. seems a bit long winded to me .. I must be doing something wrong. Does anybody have a tutorial handy thats a bit more complex than just changing 1 body morph .. i.e one that changes say pbmBarbarian, pbmSuperHeroine and a few others etc... If this makes no sense I apologise, just say and I will try and reword it.
Valandar ( ) posted Tue, 23 April 2002 at 2:45 PM
Tigger: Just right click on "Victoria", and you have the option to "Uncheck all morphs"
Remember, kids! Napalm is Nature's Toothpaste!
LdyMox ( ) posted Tue, 23 April 2002 at 2:46 PM
I am not the best at Talour yet but here's 2 things. - You would need to do the pbmSuperHeroine and pbmBarbarian seperatly. i.e select all the SuperHeroine and process and the select all the pbmBarbarian and process. You can do them all at once but It produces strange results. To deselect all the morphs on the model right click on for example "Victoria2" and there will be a deselect all option
LdyMox ( ) posted Tue, 23 April 2002 at 2:48 PM
hehehe you 2 beat me too it as I wrote the response.
FLTigger ( ) posted Tue, 23 April 2002 at 2:54 PM
Thanks y'all, yep Ron, found your free tutorial and that helped me a lot, just wondered if I had mis-interpreted it as it seemed to be a long winded approach if I had several body morphs to link in.
scifiguy ( ) posted Tue, 23 April 2002 at 3:34 PM
I'm sorry to say that you are wasting your time with the Changing Fantasy Suit. Tailor can't deal with the geometry switching nature of it. When you start changing the dials to switch pieces of the suit, your morphs there will vanish and the morph dial won't affect the new piece. :( It works great on most other clothing though.
FLTigger ( ) posted Tue, 23 April 2002 at 3:59 PM
Nah, in this case I actually want the default clothing on the model so it will be OK. Got the hang of it now, this is an awesome program, just got a little conflustered at the start learning the quirks of it. Thanks again.
