have you changed both the trans max and the trans min settings? what are you trying to do? make sections invisible, or the whole thing invisible? if it's the whole thing, make sure your trans map is totally black, otherwise make sure the black parts are mapped properly onto the suit like on a texture map hope that helps, otherwise...hmm, I'll have to tax my brain and think about it again, but I don't think the catsuit needs a patch to be made transparent SewerRat
I've changed both settings (all up and down the scale), with and without a transmap. I even tried making big black blotches in the transmap to make it transparent. No dice. I have tried a couple of other P4 Trans maps posted here for the catsuit, and they don't seem to work either. I have used transmaps on other P4 default clothing, and they work.
Can't seem to make the P4 Catsuit transparent. I can't do it with the transparency settings, or with a transmap. Is there some patch for the file?
