Tue, Jan 7, 12:16 PM CST
Subject: Foleypro contest almost over...less then two weeks left
foleypro ( ) posted Sat, 27 April 2002 at 7:23 PM · edited Fri, 02 August 2024 at 7:28 AM
Attached Link: http://foleypro.topcities.com/downloads.htm
Hello all this is just to remind you that the contest is almost over and we have had only two entries now if you have downloaded the free effects before and couldnt use the tutorial well there is one that you can download and there is also one you can read online...Either way they work...Also dont worry for you folks that dont have poser you can go and download an obj file from either here on renderosity or 3dcafe or even 3dcommune and import into bryce you also can do a scifi scene useing the Magical blast as laser fire just change the color also you can use the torch fire for gunfire from the end of a gun barrel...Ect let your imagination run wyld...As always be B3D
Chere ( ) posted Sun, 28 April 2002 at 12:52 AM
Attached Link: http://www.renderosity.com/gallery.ez?ByArtist=Yes&Artist=Chere
Got one ya one more pic here.And thanks again for all of your help with the tutorial on the effects.
foleypro ( ) posted Sun, 28 April 2002 at 8:22 AM
You are more then welcome...Great pic btw
