Sat, Jan 11, 6:39 PM CST
Subject: Converting boots made for Vicky, to Mike - how?
Dragontales ( ) posted Mon, 29 April 2002 at 10:41 AM ยท edited Sat, 11 January 2025 at 4:17 PM
First off, thanks to those who helped me locate a cool pair of boots. My problem now is getting boots made for Vicky, to fit Mike. I'm new at the converting process, and would like to know what the steps are in converting these boots. When I conform them to Mike, they dont' line up right. I can make them line up, but will they still be conforming? Do I need to bring them into another program to morph them better, etc. Basically, is there a step by step process that I can follow, tutorial, etc. Or just let me know here. Sincere thanks for all your help. Dragontales
c1rcle ( ) posted Mon, 29 April 2002 at 10:47 AM
the best thing to do is line them up than change the parent for each 1 to mike's feet then save them to the library with a different name, then you've got boots that will conform to Mike as well as Vicky Rob p.s select each boot seperately click on object on the menu choose change parent then choose the correct foot for each boot, just in case you needed to know how :) hope this helps
Dragontales ( ) posted Mon, 29 April 2002 at 11:00 AM
Actually, yes, that helps quite alot. It's something I didn't know. Too bad I'm at work, I'd be trying it out right now. Thanks again, Dragontales
c1rcle ( ) posted Mon, 29 April 2002 at 11:05 AM
no probs :) I only found that out the other day when I tried it on a helmet I have for one of the standard characters, it looks better on mike tho :)
bloodsong ( ) posted Mon, 29 April 2002 at 5:14 PM
Attached Link: http://www.3dmenagerie.com/index-goo.htm
heyas; i'm not sure that would quite work for conforming. if they are props (with inherit bends turned on), that would be fine. if i were doing it, i'd say bring in the boots, line them up and size them to michael's feet, then export them as a new obj for a new conforming cr2 made for michael. if you don't have anything that conforms to michael (or you have stuff, but it doesn't have feet), you can make a base conformer cr2 by following my painlessly easy conforming clothing tutorial ;)
