Thu, Dec 26, 12:38 AM CST
Subject: Is it possible to reverse "replace body part with prop?"
communion ( ) posted Mon, 31 January 2000 at 4:19 PM · edited Thu, 26 December 2024 at 12:35 AM
Anyone know if you can reverse this? Thanks,
Anthony Appleyard ( ) posted Mon, 31 January 2000 at 4:52 PM
Only by text-editing the .CR2 file, as far as I know.
Cage ( ) posted Mon, 31 January 2000 at 7:57 PM
I went through the process a few weeks ago. It is long and involved. I deleted some of the wrong text in the .cr2 and ended up with invisible parts. Ultimately I replaced the prop body part with another prop. If you put an asterisk (*) in front of the section in the .cr2 which contains the custom geometry, Poser will apparently delete those lines the next time the .cr2 is saved. Easier than selecting and deleting the whole geometry. If you try it, and it works, let us know!
Cage ( ) posted Mon, 31 January 2000 at 7:58 PM
Mason mentioned something about trying to build the capability into Morph Manager. Don't know if he's serious about it or not.
Jackbox ( ) posted Mon, 31 January 2000 at 10:44 PM
I did that B4 in P3 wz john's poser libary file Editor, open the cr2 file,delete the custom body part or parts. then open this cr2 in poser, change figure and click "keep current proportion," the missing parts will be replaced by the original figure.
