Tue, Feb 18, 10:46 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Picture in Button
Grammer ( ) posted Sat, 13 April 2002 at 5:01 AM · edited Mon, 10 February 2025 at 5:21 PM
Hi: I am currently writing a small programm which can evolve facial expressions - my question, is how do I get apicture from a file into a button ? Thanx, Karl
Montressor ( ) posted Sun, 21 April 2002 at 12:41 PM
First construct at label like this:
label = Label(root,bitmap=, ...other options ...)
use the place geometry manager to put it inside your button wherever you want it.
If you need more code, let me know...
Montressor
Grammer ( ) posted Mon, 22 April 2002 at 10:00 AM
Thanx, in the meantime I had managed this, but in a weird way. I couldnt get an image from poser through PIL and then into TK. Now I save it from Poser as a TIF, load it in PIL, then save it as GIF and finally load it into TK. Apparently nobody could help me to find a better way of bringing a picture from Poser to TK. Is there one ? The programm itself uses a genetic algorithm to evolve facial expressions - the user clicks into one he likes, and then the evolution process takes place. This can be done with faces and even whole figures.
Montressor ( ) posted Wed, 01 May 2002 at 5:25 AM
Nice idea. However, Poser (at least, as far as I know) will not save gifs directly. wxPython will handle jpgs, which it will save, but not Tk.
Montressor ( ) posted Thu, 02 May 2002 at 12:06 AM
Oh, am I dumb! Why not just export the jpg and then use ImageTk.PhotoImage to get it back in?
