Fri, Nov 22, 1:13 PM CST
Subject: Stumped, what is OBP format? Work on Mac Bryce4?
Eric Walters ( ) posted Mon, 31 January 2000 at 10:40 PM · edited Sat, 02 November 2024 at 4:07 AM
Hello, I am puzzled as to what .obp format is. I cant seem to open or import it into B4 on my Mac-I get an "unknown format" message. Any clues here? thanks! Eric Walters
KenS ( ) posted Tue, 01 February 2000 at 12:46 AM
I know with mac .OBP's(Bryce Object Format) we add the .OBP extension to the files, you might try renaming the file and removing the extensio and see if it works. Goto CREATE and click the small arrow to open the Bryce Presets menu then click Import and locate the file. hope that helps FastTraxx
Eric Walters ( ) posted Tue, 01 February 2000 at 1:50 AM
Thanks! I'll give that a try! Thanks Eric
adam ( ) posted Wed, 02 February 2000 at 12:01 AM
get to know obp. format. You will be using it a lot. Most of the downloads at on the free stuff section are in obp format. You should also get familiar with bsk format. This is the format that the sky presents are in. When you export a sky preset, it is in bsk format, also when you import the preset you must open up sky/fog presents and import that way. Just in case you didn't know =) -Adam
Eric Walters ( ) posted Wed, 02 February 2000 at 12:21 AM
Thanks Adam! I did not know that! ---Eric
adam ( ) posted Sat, 05 February 2000 at 11:35 AM
Yeah. This is what I do: when I receive an ebot message from renderosity, I check out the page and if there is inportant information on the page, I don't delete the ebot. But since you did not receive an ebot because you just added you thoughts to the thread, you can copy and paste the message to a text program or something on your computer offline. But when I reply to your message right now, you will receive an ebot, so save this one. You now have an ebot linking to this thread. -Adam
