Sun, Feb 2, 10:02 AM CST
Subject: Image textures and PS filters
Erlik ( ) posted Thu, 02 May 2002 at 5:07 AM · edited Sun, 02 February 2025 at 10:01 AM
First, if an image texture is not directly lit, either by sun or by a light, I get the default grey colour. Why? Second, I defined the Photoshop plugin folder as the plugin folder for Bryce 5. But I cannot use Photoshop's filters like texturizer or artistic or levels, only the filters that I installed separately, like Eye Candy and Almathera Lightning Maker. What did I do wrong?
-- erlik
AgentSmith ( ) posted Thu, 02 May 2002 at 5:51 AM
I'm not sure about your first question. Photoshop's own filter's will only work with Photoshop (and Image Ready), they are not carbonized to be used by other programs, bryce included.
vasquez ( ) posted Thu, 02 May 2002 at 5:55 AM
About the firts question... I think you should set the ambient property of the material related to the texture (like diffuse). Hope it helps
Erlik ( ) posted Thu, 02 May 2002 at 6:10 AM
Vasquez, what do you mean "set the ambient property"? Put a value which is not zero? I think I tried something like that, but then I didn't get the image I wanted. It was ... diffused. :-) Or, better to say, the colours were washed out.
-- erlik
vasquez ( ) posted Thu, 02 May 2002 at 8:13 AM
That's the same object with the same texture, the only changes I made in the two renders is indicated by the red arrow, you can also play with the darkness of the shadow on the object changing the ambience (green arrow). I hope I havw correctly understand your request. Cheers.
Erlik ( ) posted Thu, 02 May 2002 at 7:01 PM
Yes, you can. Thanks. The result can be seen in my post "May Challenge part WIP", on the wheel of the plane. I put the image here, but then deleted it. The other post is a more appropriate place.
-- erlik
