Fri, Nov 15, 8:21 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: HELP! Figures won't show in posing window!
vmiller ( ) posted Thu, 02 May 2002 at 7:51 PM · edited Fri, 15 November 2024 at 6:34 AM
I have looked for help in the support and FAQ areas of Curious Lab, etc..
but can't solve this problem. I can't see the figures in the posing window.
If I click on a part of a figure or run my cursor over the window I can see
a faint line drawing of the figure ... the highlight indicating an area or
part. I have tried adjusting the video hardware acceleration and have
changed the color depth up and down, and the screen resolution, but no joy.
Selecting different view settings such as line, hidden line, etc.. doesn't
help, and I haven't come across any settings I may have set wrong. I have tried erasing my preference files, and setting the start-up to factory defaults. The figures are there, squarely in the middle of the window, just invisible until I run my cursor over them and a body part is them highlighted and then barely visible as a dotted line.
To make things more complicated I have two video cards with two monitors,
one a hot NVIDIA quadro II pro (in my graphics port) and one an old Matrox
Millenium (pci). My computer is a Dell Workstation 530 with dual xeon
processors and 1 gig of memory. I am running Windows 2kpro. I have heard something about Poser not
working with systems with "to much memory", Could this be?
Any help much appreciated!
VMX
bloodsong ( ) posted Fri, 03 May 2002 at 10:03 AM
heyas; is this all your figures? usually when the figure hiearchy is there, but the figure geometry isn't, that's an indication that the group names of the obj file don't match the body part names in the cr2. if this is happening with the standard figures, try going into the geometries directories and deleting the rsr files there. then re-load the figure and see if that helped.
vmiller ( ) posted Fri, 03 May 2002 at 10:25 AM
Yes it is with all figures. I have deleted the rsr files, rebooted, restarted, but no joy. I have uninstalled the program, gone through the registry, reinstalled the program, still no good. I have version 4, with the 4.03 update. Doesn't help to install the poser plus package. Things work fine on another, older computer.
VMX
vmiller ( ) posted Fri, 03 May 2002 at 3:48 PM
A suggestion from another forum solved the problem! If you have TO MUCH virutal memory, then Poser doesn't work right. Seems kind of backward doesn't it? anyway, I reduced my virtual memory from 3 gigs on one drive plus an addition 3 gigs on a second drive and all it well. VMX
princevlad ( ) posted Tue, 28 May 2002 at 10:47 AM
HELP PLEASE; i cannot get the mermaid models into thje poser work window at all though I can see them all in the drop down menue to the right how can I get them to show up in the poser window so I can do work on them. They are not the only ones to do this though almost all the other pics work fine. I have used the Pinstall program to install all theses files. Any help will be much aprecciated than you
