Sat, Jan 25, 5:05 PM CST
Forum Moderators: Staff
Subject: question about Compose
judith ( ) posted Mon, 06 May 2002 at 8:43 AM · edited Sat, 25 January 2025 at 8:42 AM
Do any of you Poser Gurus know if there is a size limit on what the program will export? My obj loads in fine, but I'm only able o export certain parts of it. Suggestions or comments appreciated, please.
What we do in life, echoes in eternity.
E-mail | Renderosity Homepage | Renderosity Store | RDNA Store
lgrant ( ) posted Tue, 07 May 2002 at 1:39 AM
I have found that on large files, Poser gets confused when exporting the OBJ. I don't know at what particular size this happens...just with big files. When exporting large OBJs, I usually chop them out of the CR2 or PP2 with a text editor, so I know Poser won't corrupt them. This is ugly work, especially if you're not accustomed to grubbing around inside of CR2 and PP2 files. You might be able to enlist the aid of a friend in chopping up your files. lynn
judith ( ) posted Tue, 07 May 2002 at 9:43 AM
Thanks Lynn, In the end, I did end up using Poser to chop up the files, as Compose could not handle the large obj. It's a slick program, but it does have it's limitations, perhaps due to the fact it's Java based. ~judith~
lgrant ( ) posted Tue, 07 May 2002 at 9:56 AM
Judith... Oh...I though you were asking about Poser export limitations. (Guess I didn't read the title of the thread...oops!). I'll have to look into Compose...I'm not familiar with it, and I like learning about new tools almost as much as I like getting new models. BTW...You could also have used UVMapper Pro to split it up: bring in the file, delete the parts you don't want in the first group, save it, bring in the original again, delete the parts you don't want in the second group, save it. (UV Mapper Classic doesn't appear to have a delete, by the way.) Glad you got the problem resolved. Lynn
judith ( ) posted Tue, 07 May 2002 at 10:12 AM
Attached Link: http://www.morphworld30.com/tutorials/extract.html
You may find this link of interest Lynn :)
lgrant ( ) posted Tue, 07 May 2002 at 10:21 AM
Thanks, Judith...I'll check it out tonight when I get home. Lynn
