Sun, Feb 16, 6:46 PM CST
Forum Moderators: Staff
Subject: Movies & Render
lupey1 ( ) posted Tue, 07 May 2002 at 4:56 AM · edited Thu, 30 January 2025 at 7:36 AM
Well I have about a 30 second movie made (after I figured out the movements and key steps etc) But when I make the movie it does not render it. I have looked all thru the buttons and there is nothing in my movie making that says anything to do with rendering. Where am I going wrong? Thanks in advance!!
nyar1ath0tep ( ) posted Tue, 07 May 2002 at 2:27 PM
Set up the movie in the Animation Menu/Animation Set-up screen. Make the movie in the Animation Menu/Make Movie screen by clicking the OK box. Maybe your copy is corrupt and the OK button doesn't work, or you have memory problems, or you didn't read pages 260-267 of the manual. Message671422.jpg
Ericroy ( ) posted Tue, 07 May 2002 at 3:58 PM
Also check that the play range at the bottom of the key frame page is set for the entire animation. You can also set it on the make movie start/end selection. I hope this helps, Ericroy
lupey1 ( ) posted Tue, 07 May 2002 at 4:21 PM
Appreciate all the help. I found out what I was doing wrong. On the make movie button I wasn't switching the Quality button to "current render settings". Guess the manual does help :D THANKS AGAIN for all the help!
