Wed, Jan 8, 3:56 AM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 06 5:28 am)
Are you up to the challenge??
Subject: Flash Export?
odeathoflife ( ) posted Mon, 06 May 2002 at 3:26 PM · edited Tue, 07 January 2025 at 6:33 PM
Hi again, I work for a webdesign company, and my employer uses flash to build his webpages, i unfortunatly do not have flash, and am wondering if there is a flash export plugin available for photoshop (he said there is one for Illustrator, but again I do not have illustrator) Thanks guys and gals you help is appretiated death
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Slynky ( ) posted Mon, 06 May 2002 at 6:16 PM
Mayhaps PS7 has some new swf export options, but I wouldn't know. As for possible plugins available for photo shop for swf exporting, my brain is telling me none such a thing exists. Illustrator as far as I know in the later versions has built in support for flash and livemotion right into the software. Macromedia Freehand also to my knowledge has powerful flash export capabilities. Photoshop though, it's worth a search, but I'm thinking your search will turn up empty. Hopefully, someone will prove me wrong.
retrocity ( ) posted Mon, 06 May 2002 at 8:05 PM
Are you looking to IMPORT from FLASH or EXPORT to PHOTOSHOP???
Because unfortunately photoshop being primarily a raster based program there's no way to export or save as SWF.
Illustrator is primarily vector and is perfectly suited for FLASH.
If you were able to export anything from photoshop it would be the vector coordinates from the pen tool and possible the raster information as a bitmap...
As for IMPORTING anything from a SWF...
Good Luck,
Rork1973 ( ) posted Wed, 08 May 2002 at 10:40 PM
What are you talking about, man ? :) A plugin to export a flash file ? You must be joking....I wish it was that simple to work with flash =) All those 'with our newest version you can export to flash' stories are just to increase sales or to make it look kool. But that's not the way it works. The only thing you could create in another program is just graphic elements. To cut down on size, with bigger projects you mainly use vector graphics instead of normal raster. That's why you would need either Illustrator or Freehand - the tools Flash has got aren't enough to make special graphics. But what you do is save it as EPS for instance, and open that in Flash & put it in your object library as a graphic. Since Flash is able to open a lot of different formats, there is no use for a plugin to export it to a flash movie straight away. The only exception is when you make a little animation in layers, which can indeed be exported as flash movie - but that's very amateur stuff and not made as an alternative to (basic) flash. So if you need to make graphic elements for your boss in Photoshop, you should use paths to make the shapes you want & save as EPS. He/she will be able to use it in Flash. But if you wanna get into flash in a normal/serious way, you can't do without Illustrator or Freehand, but most of all you need the control that Flash hands you. It's not at all difficult to get into, but you'll need to be able to understand how it works, so you can plan your projects (animations, navigation, etc) ahead and even for the most simple sites you still need to know how (action) scripting works. I might be wrong, but Flash has a 30 day trail...and it's got no restrictions, so if you go to www.macromedia.com you can try out Flash for a month (it's got pretty easy and good tutorials). Well, sorry if I'm talking too much - if you need any help, feel free to IM or email me.
dreamer101 ( ) posted Thu, 09 May 2002 at 12:31 AM
Yes, I believe they have a trial for most of the macromedia software. An alternative to Flash (for those wanting to jump in but can't wait to learn Flash) is Swish. It has 150 built in effects. Kind of a cheaters Flash but helps you put together flash very quickly. It saves files as .swi but you can export to the Flash's .swf, HTML or .avi format. They have a free 15-day trial download and to buy it's $49.95 where Flash will cost you about hmmmm I think about 10 times that much.
www.swishzone.com
