Tue, Nov 26, 6:31 PM CST
Subject: Test PWFW(poserworld.com) Skin Texture MATs
LdyMox ( ) posted Mon, 13 May 2002 at 3:19 PM ยท edited Tue, 26 November 2024 at 4:11 PM
Attached Link: http://www.darkjyhad.com/poser/PWFWSkinMATs.zip
Test PWFW Skin Texture MATs.. Ok I just wanna see if these work right. The only problem I know if is that Isidora's eyelashes don't look right(maybe someone can help find a setting that does look right) It has MATs for PWFW's Vicky Textures (Aethra[Plus eye tex mats], Isidora, Elena, Goth, Gizelle, and Aishawaya) and for the P4 High Res Skin Texture[Plus eye tex mats]
chriscox ( ) posted Mon, 13 May 2002 at 7:10 PM
Just got done checking the MATs out. The big problem that I have with them is that the default material colors are applied to the figure in addition to applying the texture maps. I almost always use the figures with most of the material colors set to white. Also you didn't mention that these were for the Pro Pack, which lead me to spend some time trying to figure what happened to Aeretha's Eyebrows only to discover that they were coming out weird due to the bump map being a .JPG instead of a .BUM file. BTW the Eyebrows bump should also be applied to the head also because the eyebrows texture doesn't stay with in the Eyebrows area only. The problem with Isidora's eyelashes is that you're using Isidora's head texture as the transparency map, which it isn't designed for. Chris Cox
Chris Cox
chriscox ( ) posted Mon, 13 May 2002 at 7:27 PM
Forgot to mention that the thumb for P4HighResEyeOlive is blank. Chris Cox
Chris Cox
LdyMox ( ) posted Tue, 14 May 2002 at 2:31 PM
I'll try and fix these problems. I can easly set the materials to white. I am not sure why the 1 thumbnail is blank but maybe I forgot to add it(plus I need to add rsr version . Unfortunally the materials I am working with are in that format.
