Thu, Jan 9, 7:33 PM CST
Subject: Bryce 5 Question?
RandC ( ) posted Mon, 13 May 2002 at 6:33 PM · edited Thu, 09 January 2025 at 10:06 AM
Thanks in advance! How do you export meshes from Bryce? Thanks
Crakmine ( ) posted Mon, 13 May 2002 at 6:39 PM
Um, well, bryce has a very very selective export. You basically can export anything without any boolean work on them, which means primitives and terrains, and thats directly under the file menu, to export, but other than that you're pretty much left dry, sorry.
petrik ( ) posted Mon, 13 May 2002 at 8:10 PM
If you select the mesh you wish to export, and then you go to attributes. (The little A that comes up at the side of the model when it is higlighted) Once in attributes... sorry I am at work so have to work from memory ... use CTRL-D (or ALT-D if. Like I say I am working from memory) this will bring up an export box. Good luck. If you have any problems let me know and I will send through the info.
Aldaron ( ) posted Mon, 13 May 2002 at 9:02 PM
Only stones, terrains and lattices can be exported.
clay ( ) posted Mon, 13 May 2002 at 10:15 PM
If it's an imported mesh select the edit option then hit control+D to bring up the export window, otherwise like Aldaron stated only native Bryce stones, lattices and terrains can be exported.
Do atleast one thing a day that scares the hell outta ya!!
EricofSD ( ) posted Mon, 13 May 2002 at 10:43 PM
Attached Link: http://www.annsartgallery.com/export.html
I have a tut up at the linked site above and Brycetech has a great one on his site.
RandC ( ) posted Tue, 14 May 2002 at 10:48 AM
Thanks guys you were a big help!
