This may be a stupid question but Im having a problem with the part of the handle that the button goes on, the one with the angled edge on one end. In the tutorial it says to set the extrusion to pipeline before setting up the envellope, but when I do that I cant seem to move points horizontally. So in the part where you have points directly above two others I cant get them in that position. I hope Ive explained this as clearly as possible. Can anyone tell me what Im doing wrong? Cheers, Max
At the risk of seeming like an idiot, I have another question. The one thing I cant seem to get right in the tutorial is the illumination on the ground, the bulb light I placed under there doesnt seem to be dong anything. I doube checked to make sure cast shadows was off on the infinite plane. Is there some other obvious detail that I may have overlooked? Cheers, Max
Ok, Post an image of what you have so far. The illumination on the ground comes from a spotlight above it positioned at approximately X=15, Y=-15, Z=15. I basically changed the distance light which is default in a new scene to a spotlight and made the settings to it as described in the tutorial. The bulb light is hardly noticeable in the scene as it illuminates the bottome side of the lightsaber very lightly. This effect is more exemplified in the ant picture I just posted here in the forum. You'll notice the underside of the ant is illumnited because I put a light source under the floor to simulate radiosity coming from the white plane beneath the ant. This scene is the showroom environment on the CD. I just added the ant and rendered the picture. -Kix
-Kix
The blade itself is a light source using anything glows. This is explained in section 6 of the tutorial. The settings I used are in the image. It doesn't look like you've turned AGlows on. It's also possible that your AGlows source is making a general global illumination that's filling the scene and you can't tell. Turn off your bulb and spotlight and make sure your ambient light is off so the blade is the only source on. Then you can tell what light the blade is producing. The light from my blade is bright and falls off sharply. Check the settings I've used for range, range falloff, and fall off rate. Keep asking questions if you're still not satsified, these are good issues to bring up. -Kix
-Kix
Well you've got me a little bit on this one. 1.) I'm not where I can look at the moment but, I think I turned on the soft shadows for the anything glows light. and 2.) I didn't have the blade stuck into the handle in such a way that it cast that shadow. It's just right at the edge and not any farther. That may make a difference. Make sure you let me know if that fixes it. -Kix
-Kix
Attached Link: http://www.renderosity.com/~carrara/tutorials/lightsaber/clickme.html
Ok, You asked for it, you got it. Leave me some comments here to tell me what you think of this tutorial. I created this dude all from scratch. It's completely different than the one I posted earlier. -Kix-Kix
