Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
tasmanet's suggestion is where I'd start as well. But I've also had a similar problem when I accidentally set the Eyebrow transparency to 100% (when I meant to do the Upper Eyebrows). When I saw the Upper Eyebrows weren't transparent I went and set them to 100% and could not figure out why I was getting this wierd bright line above the eyebrows. Eventually I went through and found that Eyebrow was 100% transparency.
I am creating a character... not that I know the proper way to do it... using Vicky, a face morp from Posette's Paradise and the amazing Yazoo texture from the market place. I had the same problem, and what I found out was that I actually ended up with 2 eyebrows in the drop down texture menu. One had the right texture applied (I used a MAT file from the Yazoo package) but the other didn't have anything to it except the color set to white. I just set the texture to the right head texture and that fixed it up. Though now I have some dials regarding eyebrows that don't do anything.
I've been working on this composition w 3 characters and all of a sudden the Daisy character has white eyebrows that I can't get rid of. It looks like someone squeezed toothpaste over them and it renders that way too. I've tried reapplying the texture files but no luck. Whats up with that? Thanks in advance for any help.
