The types of files that Poser reads directly are *.pz3. These are the actual scenes that you create. All the other files -- *.cr2 (character), *.hr2 (hair), and so on -- are loaded INTO a *.pz3 file. They're not opened by Poser directly, but loaded into a scene file IN Poser. So, what you're supposed to do is start up Poser, then load your other files, like hair and props, from the menu bar on the right side. Hope this helps :-)
Ok, the files you download for poser do not have an icon of their own, and don't need to be opened with a particular program, even Poser, which is normal ;) If you look at the files you'll see that they have their own extensions, like "rsr", or "cr2" or "pp2" or "hr2", etc. What Poser does is have these files inserted in specific folders in your Poser 4 folder, and when you load Poser, it will "know" where everything is, and load it whenever you wish. To explain: RSR and CR2 go into your Poser4/Runtime/libraries folder (and sub folders if you create your own) OBJ files go into the Poser4/Runtime/Geometeries folder (and any sub folders) PP2 & RSR files go into the Poser/Runtime/libraries/props folder (Props) (and any sub folders) HR2 files go into Poser4/Runtime/libraries/hair folder (Hair) (and any sub folders) FC2 & RSR files go into the Poser4/Runtime/libraries/faces folder (Face) (and any sub folders) CM2 & RSR files go into Poser4/Runtime/libraries/camera folder (Camera) (and any sub folders) LT2 & RSR go into Poser/Runtime/libraries/lights folder (Lights) (and any sub folders) HD2 & RSR files go into Poser/Runtime/libraries/hand folder (Hands)(and any sub folders) Actually, the RSR files shown above are sometimes created automatically by Poser, or they are included with the thing you have downloaded. To illustrate: if you downloaded a prop file, for example, you will get two files: PP2 and RSR, and you would put them in the Poser4/Runtime/libraries/props folder (or a folder within this which you created yourself). When in Poser, you'd go to the Props library (on the right of the screen in Poser), and click the prop. It'll then be loaded into the scene. Hope that's helped you, I was doing it from memory so if anyone points out an error in my instructions, I apologise, and it'd be great if they added a correction ;) Good luck, and welcome to Poser :) JoeBlack
Attached Link: http://downloads-zdnet.com.com/3120-20-0.html?qt=winzip&tg=dl-2001
I think you find if you do a search for WINZIP then download and install that you will be able to open the zipped poser files. .zip files are files containing other files in a compressed format (in this case the poser files) If i did it right clicking the link will take you to a download for it. Good Luck!But then again, one must admit that there's a certain rush when you first get it home and installed on your computer! You know, you just can't wait to start it up and set up a scene - and the manual seems so big at that moment. Once the "OH COOL!" rush wears off, the manual will be there. Best thing I found to do was pull in a character or two and then as I read the manual, I'd try the things as I read them. My .02 worth. -Viper1
Attached Link: http://www.powerarchiver.com
As far as I could make out, bellonicovix said he tried to click the poser-type files (cr2, pp2, etc) and got the "open with" dialog - "then get a file with the windows picture on it" - so evidently he already has a zip program ;) He was mainly asking about the actual file types that go into the libraries for things to be loaded, not necessarily the pz3 files, the scene files. Downloads for poser in the freestuff galleries are mainly clothing, hair, props, lights, and so on - not always complete pz3 files. BTW: Powerarchiver will open the SAME types of zips WinZip will open, and it's free ;) JoeBlackThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello my name is Ben and I have just started using version Poser 4.0..I have downloaded some hair,clothing,etc..For figures and since I am new I don't know anything about downloads about Poser 4.0..So here's the thing,I download the file,open the .zip,then get a file with the windows picture on it and it asks "Open with.."..I put Poser but it still doesn't open it up..I mean the Poser opens but not the hair..Can someone please explain what they usually do,even if it's not related at some times..I need help.Thank you for reading.
