Mon, Feb 3, 8:34 PM CST
Subject: Need some advice please===>
MegaJar ( ) posted Fri, 17 May 2002 at 12:49 AM · edited Mon, 03 February 2025 at 6:36 PM
Now that I've FINALLY finished shaping Link's face, my next step is his hair. You can see a shot of it above. As you can see, it's a wierd shape, very angular and sharp. I'm guessing I'll have to use magnets on an existing hair object in order to get the shape I want. Does anyone have any suggestions as to the hair object I start from? If I can get one that's already all bent like this, then I may be able to morph it into the desired shape.
odeathoflife ( ) posted Fri, 17 May 2002 at 12:55 AM
daz has animie (sic?) hair that has the two bangs coming down the front, the rest is short but it may be a good start. He wears a hat anywho
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
MegaJar ( ) posted Fri, 17 May 2002 at 1:08 AM
Cool, thanx. I'll check it out :-)
Little_Dragon ( ) posted Fri, 17 May 2002 at 1:12 AM
I was thinking that the Wonder Wedge (also at DAZ) might be able to pull this off.
MegaJar ( ) posted Fri, 17 May 2002 at 1:34 AM
K, thanx :-)
TheDaedalus ( ) posted Fri, 17 May 2002 at 2:35 AM
Those would be my suggestions - I've also been thinking about a project like this, and have come to the same conclusions. It certainly sounds like you've put an awful lot of work into this! When will we be able to see the finished product? Good luck! Aaron
Marque ( ) posted Fri, 17 May 2002 at 10:40 AM
Also Syyd's hair at runtimedna.com might be exactly what you are looking for. Marque
MegaJar ( ) posted Fri, 17 May 2002 at 3:26 PM
Marque: I used the search engine at runtimedna.com, and didn't find any hair made by Syyd. Which one do you mean?
Marque ( ) posted Fri, 17 May 2002 at 3:48 PM
It's not free it's in the store. It looks a lot like the hair in your pic though. If you go to the store and look you will find it. Marque
MegaJar ( ) posted Fri, 17 May 2002 at 8:19 PM
Ok, I went to the store, and I flipped through EVERY PAGE of products. There was no hair that even resembled the one above. Are you sure we're talking about www.runtimedna.com?
