Fri, Nov 15, 3:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: Help! Searching blMilWom.obj file
marsuser ( ) posted Fri, 17 May 2002 at 2:08 PM ยท edited Fri, 15 November 2024 at 1:32 PM
Somebody! Anybody!
My blMilWom.obj file has dropped dead due to unexpected technical problem. Help, if it possible.
Thanks,
marsuser
MadYuri ( ) posted Fri, 17 May 2002 at 2:20 PM
Attached Link: http://www.daz3d.com/pages/dp/contact/contactmain.html
Contact DAZ, they will set you right. ;)
Marque ( ) posted Fri, 17 May 2002 at 2:52 PM
Do you have the original install file? If so you can just re-install it. Marque
PhilC ( ) posted Fri, 17 May 2002 at 3:08 PM
If you are using Poser 4 you may just need to delete the file C:Program FilesCurious LabsPoser 4RuntimeGeometriesZygotePeopleblMilWom.rsr This can sometimes get corrupted. Poser will build a new one next time you load the figure.
CryptoPooka ( ) posted Fri, 17 May 2002 at 3:28 PM
Went through this when Poser went belly up on me. I think I might have been better off just reinstalling the extras after I reinstalled Poser, but I just moved the old directories ... and got a LOT of the .obj file errors. I finally had to sit down and go through them, one at a time, loading to see what would load, then killing the rsrs of the ones that didn't.
c1rcle ( ) posted Fri, 17 May 2002 at 3:43 PM
scrap the rsr in geometries once a month and you never have to worry about the errors again, just remember it's only the rsr files in geometries leave the others alone (or else) (-: Rob
smerc ( ) posted Fri, 17 May 2002 at 8:13 PM
If none of the ideas work, contacting DAZ is your best bet. They have very good customer service. smerc
