It was the inner mouth geometry that was producing the problem. I solved the problem by first making the skin and the lips of the head transparent, making the inner mouth visible. Then, using the group tool, I selected the inner mouth by material just as Allerleirauh suggested and then deselected the vertices except for the ones at the mouth corners. I then created a magent, set its mag zone to affect only the selected inner mouth vertices, then used the magnet to push back those pesky protruding vertices. I then saved the modified geometry as a morph then combined it with Traveller's lip corners back morph to create a corrected morph. I'll post the corrected morph as soon as I find the webspace to do so with Traveller's permission.
I just wanted to report that some invisible geometry inside the mouth cavity is causing artifacts to be evident when using Traveller's lip corners back morph that he posted in his site. Using the group tool and magnets, I've only been partially successful in isolating the offending vertices, but their invisibility in some positions is making it very slow going. If someone has a way of making this mouth cavity geometry visible so that areas that break through the skin become obvious, it will make things easier to remedy these artifacts.
