Sat, Feb 15, 5:14 PM CST
Subject: Hair morphs
MandyFox ( ) posted Tue, 21 May 2002 at 4:07 PM ยท edited Sat, 15 February 2025 at 4:48 PM
Hi, I'm trying to do an under sea pic and I need Vicki's hair to look like it was either wind swept or flowing under water in a current....can you tell me of any morphs that you know of or any way to make her hair look like that? FYI I'm either using my Total Hair or Anton's Magic hair
melanie ( ) posted Tue, 21 May 2002 at 8:19 PM
You might have to do that with post work. You could use a morphable hair that will blow it backward, then use a smudge tool in Photoshop or PSP and "brush" it out to look like it's flowing in the water. Melanie
bikermouse ( ) posted Wed, 22 May 2002 at 1:47 AM
I had limited success useing "point at" but the hair wants to recede or otherwise looks foolish. If you're talented enough, you might be able to make your own underwater hair models using the information in a tutorial called "morph hair" or something like that. I think its in renderosity's poser tutorials. It uses the idea that you can change hair models by setting a parameter dial. Then you could make a series of hair models showing the changes you want, keyframe them and set the dial to change at certain points ... It could work? Sounds so complicated ... Message671424.jpg I wish I had the time and talent to do it.
Phantast ( ) posted Wed, 22 May 2002 at 4:48 AM
I think postwork is the best option here.
bikermouse ( ) posted Wed, 22 May 2002 at 7:02 AM
"... We do these things not because they are easy but because they are hard !" - JFK on going to the moon. The reference is to a download called "dial_a_hair" which I couldn't find, sorry.
