Mon, Feb 10, 1:28 AM CST
Subject: Question in Vue!!! helpppp!!!!
zer0 ( ) posted Mon, 27 May 2002 at 7:16 AM ยท edited Mon, 10 February 2025 at 1:25 AM
hi tehrei got vue the otehr day and im new to it, when im at the view windows if i move something it appears the background in white, if nor it is gray, but if i create something and move it the gray thing will keep track of everymove... that is annoying how do i change that??
YL ( ) posted Mon, 27 May 2002 at 7:29 AM
Hi zer0, is it with Vue4 ? Does your problem arise with simple scenes ? As I can see on this forum, I suggest you to disable OpenGL (if already enable)... Message671426.jpg Yves
gebe ( ) posted Mon, 27 May 2002 at 7:43 AM
First of all, you do not need to disable OPENGL, do this only if your graphic card doesn't support it. You can leave it or, ifyou prefer, just click at top of each of the four windows in the icon and choose "WIREFRAME". The "grey thing" in speaking about an object can be colored in other color to see it better (see image above). Now, you speak about a grey think keeping track of every move. Do you mean it let's a red line behind it when you move it? Then you have animated your object. Please explain a little better what exactly is your problem or post a sample image. Guitta
zer0 ( ) posted Mon, 27 May 2002 at 8:20 AM
ok see the image, the gray window is when i dont click on anything and the white one is when i move something, the white shwos me how it will look but the gray just confuse me
gebe ( ) posted Mon, 27 May 2002 at 8:38 AM
HM! Your 4 Windows should be white, not grey. 1. Click at HELP in the tope menu and choose "ABOUT VUE" from the list. Read if you have version Vue 4.06-02 If not, go to e-on's site and get the FULL UPFATE 4.06. 2. If you have already Vue 4.06, do what Yves said before. Go in FILE--->OPTIONS. This opens a new window. At right of it, uncheck "USE OPENGL". Click OK; Close Vue and fire it up again. Is the "grey" problem gone? If yes, your graphic card may not support OpenGL. Please let us know. Guitta
zer0 ( ) posted Mon, 27 May 2002 at 8:46 AM
hey i got the 4.00 version ill upgrade now, ill tell u later if it works, thanks man
YL ( ) posted Mon, 27 May 2002 at 12:07 PM
lol zer0, Guitta=gebe is a woman . But I agree it's not an evidence when you are new to here. I discovered recntly that Guitta is a woman when.... someone here said 'her' in an old post. Message671422.jpg and "hundred of pardons" to you Guitta Yves
gebe ( ) posted Mon, 27 May 2002 at 12:17 PM
No problem Yves:-) Guitta
