Sat, Nov 30, 10:42 PM CST
Subject: Bryce 5 quits in OS 10
harlann ( ) posted Sat, 25 May 2002 at 6:37 PM ยท edited Sat, 16 November 2024 at 7:40 PM
Anyone else have this problem? When importing an obj, I get a message dialog box saying that I need to find the texture map in the next dialog box that appears. Bryce quits just as I click either cancel or ok. Every single time. Any ideas on how to solve this?
AgentSmith ( ) posted Sat, 25 May 2002 at 10:39 PM
Do you have the B5.1 patch applied?
Zottel1 ( ) posted Sun, 26 May 2002 at 2:32 PM
I had a similar problem using a *.jpg as a Texture. But it worked a day later. OS X.1, Bryce 5.1. Maybe it has something to do with the *.mtl File (Texture Information) that usually is generated with an *.obj File. Try another Format - dxf?
harlann ( ) posted Mon, 27 May 2002 at 9:25 PM
Yes, I applied the 5.1 patch. And since I use downloaded models exclusively, I have no choice but to use what I can get. Sometimes, the only option is an obj. Thanks for the replies.
AgentSmith ( ) posted Mon, 27 May 2002 at 10:39 PM
Attached Link: http://home.europa.com/~keithr/Crossroads/index.html
This is a shot in the dark, but it has, at times helped me when a downloaded .obj, didn't like to be loaded. It's a freeware 3d file format translator. Try converting your model to a .3ds, or whatever, see if you can make it work.
inyerface ( ) posted Tue, 28 May 2002 at 7:57 AM
turn off os9 in background- X works better alone for me.
artcar ( ) posted Tue, 28 May 2002 at 3:59 PM
Workaround solution.
If you restart your Mac in OS 9 instead of OS 10 you can import objects in and then save them. Then change your startup disc back to OS 10 and restart. Then you have all your objects and your working in OS 10.
JMPerkins ( ) posted Tue, 18 June 2002 at 1:19 PM
Here's your solution, if you haven't found it yet... when importing your .obj file into bryce, make sure the texture images are in the same folder as the .obj and .mtl files. I came across this a few months ago and that's the only solution I could find.
spratman ( ) posted Tue, 18 June 2002 at 3:15 PM
I've used the same solution as JMPerkins. That is putting all files associated with the OBJ in the same folder. It's a pain for sure. Don't forget you need ALL the textures.
