Wed, Dec 25, 1:05 AM CST
Subject: Problems with Files from poser into Bryce
Darkness ( ) posted Fri, 11 February 2000 at 4:04 PM · edited Mon, 25 November 2024 at 11:05 PM
Hi I've created a fully dressed figure standing in a searching pose, with textures applied to the clothing, the problem is, i want to use this figure in Bryce but which Export-function should i use because the Figure is still in his pose but the clothings are back in standard position and also without textures.. how can i solve this Thanx in advance
picnic ( ) posted Fri, 11 February 2000 at 6:09 PM
You need to 'configure' the clothes to the figure. Then you export as wave object. In the hierarchy, you will most likely be sure everything is checked except 'ground'. You will then 'import object' in Bryce. You will be asked for textures (I sometimes find it just easier to not worry about textures in Poser and then just bring them in in Bryce). However, you MUST have the clothing configured or fit to the figure before exporting--you can do none of this in Bryce. Diane B
Darkness ( ) posted Sat, 12 February 2000 at 9:38 AM
I exported the Clothed&textured figure as a OBJ imported this in Bryce4 but when when i press Render no questions of the textures are being asked... and i get a "metal" human what am i doing wrong??
picnic ( ) posted Sat, 12 February 2000 at 9:45 AM
Sometimes that happens (grey, you mean). Go to Spike's tutorial and follow it for texturing the Poser figure. The URL is http://www.mindspring.com/~zonefive/ and go to tutorials. It will show you how to apply and tweak textures in Bryce from Poser (also transparency maps). BTW, the question of finding a texture is done by Bryce when you import the figure. If it didn't ask you then, it won't. This happened to me yesterday when I imported figures with a lot of clothing, hair, etc.--I just applied all the textures in Bryce. In fact, I didn't even add any textures to some of their clothes, boots in Poser because I have many more options in Bryce G Diane B
Darkness ( ) posted Sat, 12 February 2000 at 11:56 AM
Thanx this is a major help i used the tutorial and tatatataaa the texture questions were asked immidiatlty en finally my poser figure is visible in Bryce
