Thu, Feb 13, 6:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 5:20 am)
Subject: how to make posable props?
triceratops2001 ( ) posted Thu, 30 May 2002 at 8:19 AM ยท edited Thu, 13 February 2025 at 6:20 AM
I hope to make a room and hope to look inside at different angles, so I hope to make the walls move lower. I import an obj file, and tried a morph. But the result is different part goes into different scale, parts separate. I search here and found about posable props, but cannot find what I needed. Many of the message I found had talk about the tutorial at sam's 3D. Yes that is a very good tutorial, but that's talking about making a fiugre. I hope to know how to make a posable props... thanks!
SAMS3D ( ) posted Thu, 30 May 2002 at 8:43 AM
Hi, poseable props are considered figures in Poser. If it poses it has coordinates, if you are talking about moving your object along the X,Y,Z axis or scaling the prop that is indeed different, but you use the dials to accomplish this. What exactly is the problem you are having? Sharen
smerc ( ) posted Thu, 30 May 2002 at 7:24 PM
SAMS3D is the best tutorial for what you are looking to do. If you want something a little more advanced and for conforming clothing, then I recommend Philc's Tutorial CD. Using the SAM3D tutorial I was able to make this poseable collapsing bridge. smerc
smerc ( ) posted Thu, 30 May 2002 at 7:27 PM
oops, meant to ask. Can you show us what is happening here with a picture: "But the result is different part goes into different scale, parts separate."
