Mon, Jan 13, 2:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Crashing on Johnsta'a Walls and Windows.
arcady ( ) posted Sat, 12 February 2000 at 7:14 PM ยท edited Sat, 30 November 2024 at 10:11 PM
Hello; Ok, I downloaded them way back when they first came out and am now finally unzipping the buggers. I have: Wallpack.zip Wallpack2.Zip Wallpack2Cr2.Zip WindowPack1.Zip DoorPack1.Zip DoorPack2.Zip DoorCore.Zip FancyBay.Zip CutGlassTrans.Zip HiWinWall.Zip I installed them in essentially that order as well. SO, I first installed the WallPack.Zip and added a wall to a scene I was working on. I thought "gee that looks cool, let's unzip the rest of theses and then play around. After unzipping the rest of it all I try to add in a wall with a window and I get several errors (cannot open Wall.obj) but it does show up. So I save, close the file, and try to do a little work on getting a gun I downloaded in 3ds format to scale right. Finish that up and reopen my earlier scene. I get those errors again but this time one wall is missing and the other there. So I try to add in the missing wall and I crash Poser. So... I remember that these walls had a bug in them and that one of the files was a patch to one of the other files. But I don't remember who was what. Is there some Zip in my list above that I should not install? Or some order I should install them in?
Truth has no value without backing by unfounded belief.
Renderosity Gallery
CODY ( ) posted Sat, 12 February 2000 at 8:43 PM
Don't hold me too this but.... I had the same problem, Then I loaded the corrected files over the old ones...I think that is how you do it??? It did correct the problem for me..
arcady ( ) posted Sat, 12 February 2000 at 9:07 PM
I deleted them all, then reinstalled them all. Not sure what I did differently. When I compared dates my 'correction files' had the same size and dates as the files they were supposed to replace. So I chose not to replace. It 'sort of' works now. They load, but I get an error message: "continue looking for missing files?" To which I must answer 'no' in order to succeed in loading. However I save them along with a character I am working on standing next to one of them and then when I later load that file I get no errors. Odd to say the least.
Renderosity Gallery
LoboUK ( ) posted Sun, 13 February 2000 at 4:43 AM
I get the same "continue looking for missing file", I think (perhaps) there was a wood texture for the frames originally which wasn't included in the zip. When they load, I simply save them back into the library so they no longer look for the missing file. There is a corrected OBJ-zip file, one of the OBJ files needed to be replaced. It should still be in the Free Stuff pages. Paul
