Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 11:51 pm)
You'll need to open to joint editor and reset the figure's center to fix this. What I personally find works best is to select the body part the I want as the center, open the joint editor, write down what that body part's center is, then select body and set the center value there to what I wrote down. I hope that made sense.
does anyone know how to reset the figure circle to encompass the figure that you are working on. Some how my figure circle is way off and every time I try to twist or rotate the figure body it flys around the display area. It is hard to get a handle on what you want your character to do. I hope someone can point me in the right direction.
