Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
To my untrained eye, the figure looks better in Poser. In Lightwave, she vanishes into the shadows. I'm sure that's just a matter of setting up the lighting. Everything else looks much much better in the Lightwave version. For people, Poser isn't crappy as some would let on I think - if you get the lighting & colors right. So far, I have to say the most impressive renders I've seen were done in Cinema4D, a cut above Max, LW, Truespace etc., especially if you're talking about "photo-realism."
When setting up a scene to render in Lightwave, first turn off Global Illumination (set the light color to black at 0%). GI gives your scene overall flat color and messes with your shadows. Then play with your lights, you'll get wonderful results. If you can, get a copy of "Digital Lighting and Rendering" by Jeremy Birn
I do agree the poser render did come out very good. except for the shadows. Thanks for the links.. i will cehck them out... wow! there is so much to learn.. one thing i did learn is that by applying the pricnaples of radiosity with in poser... by using multiple light with carying intesities.. simulating how light bounces... you can do a very good job.. just with poser.. I bought light wave.. thinking my renders would improve dramaitlcy over night.. of coarce that's not true.. before you can make lightwaxve or be it any program work well.. you have to understand a bit about physics and how light bounces... so my advice is... don't spend hundreds of dollars like i did thiunking you're renders will improve over night.. they won't.. you can achieve excellent results with poser... learn how works... I think my next purchase will probabbly be a book...not a priece of software. Nick
I agree alamanos. I've played with the free Poser to POVRay exporter. POVRay is a well respected render and can do some great images but the scene doesn't seem to look any better than Poser's render. I'm sure it's a matter of knowing how to take advantage of the tools. I assume you already have PorPack and used the export to Lightwave plugin. Looks like a different camera angle. The point of her hip in Poser is further from the corner of the window. I'd like a wizard which would let you: 1. Specify a lighting scheme - eg. office flourescent or individual lights (light 1 is a 100 watt GE Softwhite) 2. Define materials - Wall texture is semi-gloss paint, floor is bare wood. 3. For outdoor scenes specify location, season and weather ala Terragen. Then generate the lighting for you. I know the data is available and high-end architectural lighting packages use it. Having such a wizard would remove much of the need to a digital lighting guru and give you a good basis for further tweaking.
