Sun, Dec 15, 12:57 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 14 2:19 am)
Subject: Question in spanish
doglio ( ) posted Thu, 06 June 2002 at 9:18 PM · edited Sun, 15 December 2024 at 12:42 AM
peque pregunta para los usuarios que hablan espal. para que sirve la raya que hace el walk designer? como hago para que el sable que baje del free stuff de esta web le quede en la mano al yoda que baje de esta web tambien?
tasmanet ( ) posted Thu, 06 June 2002 at 9:42 PM
Attached Link: http://babel.altavista.com/tr
Translate to English http://babel.altavista.com/tr
wheatpenny ( ) posted Thu, 06 June 2002 at 9:48 PM
Site Admin
La raya muestra donde anda la figura. Se puede cambiar la raya para que la figura ande en la maners que se quiere. A proposito de la sable, primero, pongala en la mano derecha de yoda y haz que los dedos lo agarren. Luego seleccionela y, usando el menu "Object", haz click en "Change parent" y seleccione la mano derecha de Yoda, y luego cuando se mueve la mano, la sable guedaragarrada en la mano
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
wheatpenny ( ) posted Fri, 07 June 2002 at 11:22 AM
Site Admin
Translation: His original message: A little question for spanish-speaking users: What is the line in the walk designer for? How do I make the saber i downloaded from freestuff on this websitestay in the hand of the Yoda I also downloaded from here? My answer: "The line shows where the figure walks. The line can be changed to make the figure walk the way you want it to. As for the saber, first put it in Yoda's right hand and make the fingers grip it, then select it and, using the "Object" menu click on "change parent" and select Yoda's right hand, and then when you move the hand, the saber will stay gripped in the hand."
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
doglio ( ) posted Fri, 07 June 2002 at 1:17 PM
Thanks people you really help me :))
