Tue, Feb 4, 8:10 AM CST
Subject: Poser 4 UPDATE 117(new) BUG !!!
dunga ( ) posted Wed, 16 February 2000 at 6:50 AM ยท edited Fri, 02 August 2024 at 7:45 PM
just downloaded Poser 4.02. 117 from Larry's site. 1. there is a bug in OBJ import: as it is: after importing the obj file ALL dials dissapear, all options become gray(i.e not being able to use) no figure is present in the main window.
LoboUK ( ) posted Wed, 16 February 2000 at 7:00 AM
If you haven't already, you need to contact Larry about this. Paul
JeffH ( ) posted Wed, 16 February 2000 at 7:04 AM
Dunga, you have two copies of the OBJ import plugin installed. That's your problem. -JH.
dunga ( ) posted Wed, 16 February 2000 at 7:08 AM
I HAVE ONLY 1 obj plugin installed. I read the manuals first. SO IT is not a user problem
JeffH ( ) posted Wed, 16 February 2000 at 7:12 AM
Check the two plugin component dates and compare them to the ones in the zip.
dunga ( ) posted Wed, 16 February 2000 at 7:25 AM
Here are the problems: Every second load: VRML import is going missing every second time export of RIB, Painter, and BVH goes crazy again
JeffH ( ) posted Wed, 16 February 2000 at 7:43 AM
Poser never had a VRML import.
dunga ( ) posted Wed, 16 February 2000 at 7:48 AM
At least I found one answer. TQ
