Fri, Jan 24, 7:36 PM CST
Subject: Poser Bug Continues?
BAM ( ) posted Wed, 16 February 2000 at 8:55 AM ยท edited Fri, 24 January 2025 at 7:35 PM
Attached Link: http://www2.gasou.edu/facstaff/bmunkasy/Poser%20bug.jpg
I have posted this bug report for every patch that has come out. I have received no response from anyone acknowledging or confirming this problem. I have downloaded and installed the latest patch and the problem remains. Here is the problem. When I open P4 files created prior to any patch the running shoes included on the P4 disk are no longer applied properly. In the picture I have tried to attach you will see that the right shoe is covering the crotch region instead of being on the foot. No manner of addressing this problem that I can think of including trying to move, conform, parent, delete and reapply has worked. I have a number of P4 files in which this problem is apparent. In some of those neither shoe works correctly and in pictures with multiple figures none of the shoes works correctly. If the character is recreated completely after the patch, then the file is saved and reloaded everything seems to work fine. However, I have created quite a few characters and scenes prior to any patch that I don't want to have to recreate. Larry or someone else, please help.
MDibble ( ) posted Wed, 16 February 2000 at 9:08 AM
Have you turned off the IK for the shoes and then conformed them? :/ That seemed to fix it in my case. Mike
JeffH ( ) posted Wed, 16 February 2000 at 9:30 AM
E-mail Larry directly.
arcady ( ) posted Wed, 16 February 2000 at 12:17 PM
You have to wonder what they were thinking when they chose to have people wear shoes over their groins. :)
Truth has no value without backing by unfounded belief.
Renderosity Gallery
MDibble ( ) posted Wed, 16 February 2000 at 1:18 PM
Dr. Freud. Paging Dr. Freud. :) Mike
BAM ( ) posted Wed, 16 February 2000 at 2:25 PM
MDibble, Thanks, that solved it. Larry must've changed something because the problem didn't exist before, but it does now. Although I don't look forward to opening and fixing all my P4 files I guess it's better than having to redo them from scratch. arcady, I guess some people need the shoe for their third leg and others don't...
LoboUK ( ) posted Wed, 16 February 2000 at 2:39 PM
... of "protective boxes" forced Larry to improvise :) Paul
MDibble ( ) posted Wed, 16 February 2000 at 5:13 PM
It was probably this change that caused the problem: "Limits are now applied when IK is on. This was not being applied in the original Poser 4.0 This may change your current poses until you turn Use Limits off. " Glad to have been able to help. Mike
Geekholder ( ) posted Wed, 16 February 2000 at 11:48 PM
Obviously, the Poser male is just cold. Had you given him socks to wear he would have put a sock over it instead. Turn up the heat in your house and he'll put the shoe back on his foot. Sorry, not very helpful. Just trying to be funny.
BAM ( ) posted Thu, 17 February 2000 at 7:36 AM
Okay, in the future I will include socks. I'll do anything to keep the Poserites from revolting. I mean...they do have access to my hard drive and all...
