Sat, Nov 30, 11:26 PM CST
Subject: A file error has occurred......
watman54 ( ) posted Tue, 11 June 2002 at 3:28 PM · edited Sat, 30 November 2024 at 9:21 PM
HELP !!!!!!!!!!!!! I've been using Bryce 5.1 and Poser Pro Pak with Windows XP for a while now.....everything runs great....BUT....now all of a sudden when I try to import into Bryce (Archangel Wings...and some Characters) I get the following message....... A file error has occurred (i/o, bad media) Any clues to why ??? or Any Solutions??? Which would be way better...LOLOLOLOL Thanks everyone.... I'm stumped
watman54 ( ) posted Tue, 11 June 2002 at 3:33 PM
oh and I export as Wavefront obj files single frame .....blah blah blah If this helps to answer the question
SAMS3D ( ) posted Tue, 11 June 2002 at 4:37 PM
hmmm, I take it this never happened before....try putting it in another file and see if it takes it? i/o bad media usually refers to a cd or floppy....Sharen
Rochr ( ) posted Tue, 11 June 2002 at 4:57 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=690018
Ive read about this many times before. Check this out and see if it helps. Good luck.
Rudolf Herczog
Digital Artist
www.rochr.com
SAMS3D ( ) posted Tue, 11 June 2002 at 6:10 PM
Rochr, that is a huge help, I am sure it will help watman54...good thinking...Sharen
watman54 ( ) posted Tue, 11 June 2002 at 8:53 PM
I found a fix......opened up the file in NotePad then did the find replace thing....Finding all " #IND " text and replacing it with a space..... Worked perfectly....and Bryce accepted the 15.7 meg file beautifully..... Here's where I found it with a lot of guidance.... http://www.poserpros.com/forums/viewtopic.php?t=1215 Thanks everyone :^)
