Sun, Jan 12, 6:00 AM CST
Subject: Poser Patch problems
RKane_1 ( ) posted Wed, 16 February 2000 at 11:29 PM ยท edited Sat, 07 December 2024 at 8:44 AM
Hey guys (Yeah, I know. Long time no see.) I dl'ed the patch and am having the following problems. * I can no longer load eve or any characters I have done off that figure. (Which sucks because I prefer her over the standard Poserette. Sorry Poserette fans). It will either claim I'm out of memory (which was never a problem before) or it tells me that it cannot locate the .obj files in the geometries folder but I checked twice and its there. * When I save a .cr2, the image of it that appears in the menu to the right is actually only a portion of the image in the main window (like the mid-left third). Anyone have any suggestions?
arcady ( ) posted Thu, 17 February 2000 at 1:41 AM
She loads in fine for me. I just installed the patch about 5 minutes ago on my PC. Then I opened up Poser and loaded her in to test and she came up good. I did two test poses and exported and image all fine. My copy of her is dated 9/6/99 7:54 pm (the cr2, the obj file's date is when I converted the pcf).
Truth has no value without backing by unfounded belief.
Renderosity Gallery
RKane_1 ( ) posted Thu, 17 February 2000 at 2:51 AM
Same problem is still arising after a reboot. I will prolly have to reload the figure or something but I am not sure if the seed file is the same since Meta switched it. Any help here would be appreciated.
viper ( ) posted Thu, 17 February 2000 at 2:48 PM
delete the rsr file in the geometry folder that should fix your problem. ( but back it up first)
RKane_1 ( ) posted Thu, 17 February 2000 at 5:09 PM
I did that, but it didn't work. But themn I just reloaded her and now she works. Maybe its my systems fault. Maybe more memory is in order. I turn off most "non-essential" software when I get on but maybe eve just takes up a lot of memory. Is 128 megs enough?
viper ( ) posted Thu, 17 February 2000 at 7:16 PM
128 should be more than enough I ran 96 for a while and never had problems
Bulldog ( ) posted Fri, 18 February 2000 at 9:14 AM
Memory can't be the problem. I am still running 56megs on a old machine and don't have problems with poser or eve.
Memory can't be the problem. I am still running 56megs on a old machine and don't have problems with poser or eve. And I have another machine that has 32megs and it runs poser too.
