Thu, Feb 6, 7:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
Subject: Converting PZ3 files To Cr2 Files
buysoft ( ) posted Thu, 13 June 2002 at 8:05 PM ยท edited Sun, 12 January 2025 at 4:26 AM
Can anyone please tell me how to convert PZ3 files to CR2 files.
wipe ( ) posted Thu, 13 June 2002 at 8:16 PM
open the pz3 file into poser then (if there is more than one character) select the character in the scene and save it to any folder in the figures library by clicking on the + sign at the bottom of the library drawer. A thumbnail will be created from the view of the scene, so pose the figure how you want it's thumbnail to look. That's all.
Huolong ( ) posted Thu, 13 June 2002 at 10:21 PM
That method only saves the figure you select and the props and other figures parented to it. There is a way to save the whole PZ3 as a CR2 ... but I forgot how to do it.
Gordon
lesbentley ( ) posted Thu, 13 June 2002 at 10:45 PM
Save the whole PZ3 as a CR2? Sure that's easy, just change the file extension, and save it to a folder under the character folder.
Jaager ( ) posted Fri, 14 June 2002 at 12:54 AM
That works. But the difference between a PZ3 and a CR2 is that the former also has lights, cameras, document presets. someone else's focal lengths, lights, shadow maps All of the scene stuff can be deleted from the first section and the sketch render document data from the very end. Poser 3 would not save more than one figure in a CR2, so a PZ3 was the only way to save a complex figure. I got my start in text editing library files by cleaning up PZ3 files converted to CR2.
hogwarden ( ) posted Fri, 14 June 2002 at 4:31 AM
Hiya... You need to delete large chunks from the pz3 and resave into your library as cr2 with a text editor such as Notepad. This is quite a process... I can't describe exactly which sections to remove at the moment... I'm at work. In the next update to PBooost, this will be one of the many new features.... ripping cr2s from pz3s. Won't be long!!! Howard:)
BAM ( ) posted Fri, 14 June 2002 at 9:16 AM
Also, remember that you can import a pz3 into another pz3 by going to File/Import/Poser Document/Prop
dwilmes ( ) posted Fri, 14 June 2002 at 6:32 PM
This has been one of the dozens of tools in CR2Edit since version 3, about three years ago. Danhttp://www.zenwareonline.com for CR2Edit, ZenPaint, ZenTile, VueMaster and the complete line of Zenware graphics apps
