heyas; pose files only apply to figures; they won't apply to props. however, there is a workaround for this, if the prop is parented to a figure; that seems to work. i'm not sure if there's any special syntax to use in it. i believe you just create a mat file for your prop, and it will apply as long as the prop is attached to a figure.
can we use mat pose files 2 change the textures of props and other things, or does that only apply to mike and vicki??? im doing another armored figure (like you didnt know that was coming, lol) and would like 2 variate textures thru mat pose files if that possible..... or does any1 know of a way that i can set up the switching of texture sets in a similar fashion to mat pose files....
