My only other contribution that I had that would apply to T's method is to use a boolean difference to clip off the top of the cone. If you do that you can better focus the cones light to the breaks in the clouds. Here is a picture I did to show the clipping of how it looks on the sky. :)
Looks good. I think it would go either way depending on the type of clouds. Bright cloud, just brighten it up. Dark clouds, might need the boolean cut depending on the rest of the atmostphere. Your way probably will work best in most situations. Just have to experiment with the different methods. All this is pretty cool to learn for down the line. :)
I'm sure I've seen something about this before, but not sure if it was here or not, but is there a way to make light beams show down thru clouds like you would see on a stormy day just before the rain sets in?
