Sun, Jan 12, 12:47 AM CST
Subject: Tiling Terrains... here you go
sittingblue ( ) posted Tue, 18 June 2002 at 6:26 PM ยท edited Wed, 27 November 2024 at 5:12 PM
Attached Link: http://sittingblue.50megs.com/tutorials/tiling/index.htm
I was playing around in Vue 4 and discovered that I could tile terrains using function-generated geography.
I took a week to research and then wrote this tutorial at the link above.
I threw this terrain picture together earlier today. It is comprised of 13 tiled terrains of 256 x 256 polygon resolution. Totals polys is 1.7 million. I think I just scratched the surface of a great feature in Vue.
Charles :)
Charles
bluevenus ( ) posted Tue, 18 June 2002 at 7:49 PM
The tutorial looks great - many thanks!
NightVoice ( ) posted Tue, 18 June 2002 at 7:52 PM
That is pretty slick! A lot to ingest in that tut but it is a good one. Definately will look into it to see what else it can be applied to. Thanks for sharing!
LrdSatyr8 ( ) posted Wed, 19 June 2002 at 2:13 AM
I was having trouble with this with my Rainy Afternoon, and solved it by creating a tileable picture in Photoshop using Flaming Pear plugin Tesselation to wrap the pic along the top and sides and then saved the image as a grayscale bumpmap at 256x256 size. Then I just imported the image into the Terrain editor and viola. A tileable terrain. Was alot faster and created the same effect with the same results you are talking about. However, I'm sure that your method took alot out of you once you finally figured it out! Good job! I would have never thought of doing that myself.
