Great looking scene! Perhaps some reflections on the outside of the glass of the rest of the room? Might take away from the objects inside if it is too strong though.
I have to ask, what level of soft shadows are you doing(or pic size) that causes a 35h render with that setting and system? Higher that 5 I am guessing. :)
Try these settings for the glass or play around with them to suit your image. Try a 4% reflection setting for the glass. The menu's will look different in V2 but as far as I remember , the setting haven't changed that much since 2.*
The settings show above produced a glass as show below, the streetlamp is by MikeJ.
Thanks to all for viewing, making comments and suggestions ! >Rivers, yes you perfectly understood what I tried to explain, I think I will try very soon your very interesting suggestion ! Probably better than the idea I had to improve the above pic. >Nightvoice, I always use soft shadows greater than 5 : in that scene I choosed 10 for the two lights inside the "box", and 20 for the spotlight outside the box. Also I often use fallof greater or equal to 50% for the spotlight cause that is softening the shadow/light transition, but I don't know it it increases the rendering time > Kurka , Maybe I could impose more darkness in the room (reduce the cone angle of the spotlight), but I suppose it's a question of feeling. There are shadows under the box, the spotlight comes frome above. But I always prefer soft shadows, even when they are not real, cause they look more real to the viewer. I also often have lot of "ambiant light" in my settings to have something like global illumination in my interior scenes >hein, the menu is exactly the same that for Vue2.1 Your settings show 1.72 for refraction index which is more accurate for a crystal, but it's absolutely true that it will produce more reflections (so I should try your suggestion). Concerning reflection, I never use it since it is said that with a refraction index greater than 1, you will have natural reflection. But it's a very hard problem, since reflection is also affected by "Turn reflective with angle" setting. Cause refraction index is theoritically the parameter governing the limit angle for reflection. Does it mean that "Turn reflective with angle" account for some surface finish effects (bumps) which could modify the theoritical limit angle ? Interesting, but aniway your recommended setting 48 is greater than default from Vue I'm so happy to have this discussion and suggestion, Yves
Except the glass reflection you mentionned, the only thing I see that could improve your scene is a more... how to say it... "life-breathing" wall. try to use a bump setting or something like that... And, maybe, some not-so-clean metal materials. try to make your objects stained with dust, or something that makes them less "perfect"... It's the only thing I see for trying to improving an already excellent scene... :-)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=203540&Start=1&Sectionid=3&WhatsNew=Yes
So this is an ameliorated version, also in my gallery (see the link). Just have a rectangular box with rectangular openings (simulating a house) around the main scene .The sun shines through the openings and illuminates the scene (can be seen on the box). This (I think classical) method is very time consuming, but efficient I suppose (could be improved, for sure). So would like to try other suggestions you made. An other thing is I have not used ultra mode (rendering time probably greater than 30h, I also want to make other pictures, lol), so I had to do some postwork to ameliorate the antialiasing. ![Message671426.jpg](http://www.renderosity.com/photos/Message671426.jpg) YvesThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
