Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Suggestions Do some magnet work or morph work to lose definition on her chin, cheeks, leg muscles and arm muscles a bit and puff them slightly more. She really should have a bit of a pot belly and there are some morphs which do this job for you on Morph world I think called the rubinesque morphs. Try using a blend of both scaling and the morphs and it might work better for you. Her head may be a little TOO scaled down. You may want to take it up a little and also, you may want to make the UPPER CHEST ONLY a little less wide by a few percent (Maybe 5%) Fat is mainly water, think of it as plastic bags full of water. Areas that collect fat should sag a little more than usual and should be pronounced. On a woman, these areas are (in order that they collect fat): Thighs, belly, breasts and upper body, neck, face and upper limbs (thigh and shoulder) and then extremities. This is from basic anatomy classes for artists I took in college Hope this helps. Richard Kane
You might want to give her more of a gut, and a rounder, "puffier" face. Now that I look at it again, I have to say that if lop off about 5-10% of the legs (thickness and length - more from thickness though), thicken the arms a bit, round the face more, thin the lips, shorten the fingers a tiny bit, and replace the hair with long, light brown hair with bangs and you've got my wife...
Suggestion: Rescale the colars too! You missed on those and the chest is above the collar line! The face definately needs more work..it's not a fat woman's face...needs rounder shape, protruding cheeks, maybe even bring the bow out a bit so you give the impression that the eyes are further into her face... renapd
[[MyGallery] [MyStore]
"Collect moments, not things."
