Tue, Nov 26, 11:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: No Belly Button???
spratman ( ) posted Thu, 27 June 2002 at 8:56 AM ยท edited Tue, 26 November 2024 at 9:05 AM
I've got the "bellybutton gone" dial set to 1.00, yet I still get this dent. Is this a LoRes Vicky2 problem? The "bellybutton gone HVY" dial does no better. Is there a better way, 'sides using the cat suit to get around this? Thanx all Jon Shameless Plug--> BTW the texture used here is my ARMORTEK SciFi Combat Armor currently being beta tested and coming soon (hopefully) to the marketplace
Jaqui ( ) posted Thu, 27 June 2002 at 9:11 AM
see if you can go a bit over 1 with the bellybutton gone dial ( I've never used it so don't know) some mt will allow higher settings than 1
tasmanet ( ) posted Thu, 27 June 2002 at 9:22 AM
Well allowing that most belly buttons are in the center of our bodys I would just move your great texture slightly to the left ( right looking at it )and the belly button hole would be in the groove out of sight.
hogwarden ( ) posted Thu, 27 June 2002 at 10:42 AM
You could make the BBotton a feature by augmenting it with your texture... sort of like somewhere she can plug herself in? :)
spratman ( ) posted Thu, 27 June 2002 at 12:25 PM
Thanx for the compliments and suggestions guys..."plug herself in" LOL! That'll work for the android textures coming up next. Does this happen with the full res version of Vicky2?
Keith ( ) posted Thu, 27 June 2002 at 12:55 PM
Yeah, it does. I'm making a morph to totally eliminate it myself.
littlechris ( ) posted Thu, 27 June 2002 at 2:14 PM
You can hardly tell but if you have photoshop you could touch it up in that.
EricofSD ( ) posted Thu, 27 June 2002 at 10:50 PM
You must be using the Eve model. Remember, since Adam and Eve weren't born, they have no belly buttons.
terminusnord ( ) posted Thu, 27 June 2002 at 11:08 PM
is it really a dent, or is it texture smear? it looks to me like the texture is getting drawn out by the geometry of the belly button. The no belly button morph flattens the geometry of the depression, but all the vertices are still there and UV mapped in the same way. -Adam
spratman ( ) posted Fri, 28 June 2002 at 9:55 AM
Texture smear? Hmmm you I hadn't thought of that. I'll hafta look into it. Be a total bitch to fix tho' Thanx Jon
