Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:11 pm)
Yes, your mask drops at an angle sharply at the nostrils. In the books, Batman's mask continues parallel to his nose or at a slight incline after his nostrils. The texture map I sent you should have the corrected mask for ya! It also will make sure that the mask color doesn't intrude on the skin where the morph I made turns his nose into a mask.smile P.S. If you need me to send one without shading and highlights on it, I can do that to adapt your textures more easily if need be.
Attached Link: Download the Movie verion 1.0 now from the 3DCC!
I changed the "boxer shorts" bowing out to a little peer preasure... I moved and shrunk the emblems on Year One and Year Two... I've prepped the Movie version to easily convert it to the other two versions... any more ideas? DougI came, I rendered, I'm still broke.
