I have run into that before. From what I have seen, it only occurs if I have had my system on for a long time and I have opened and closed Poser a bunch of times. It seems that Poser is asking for more memory space and Windows is not providing the appropriate memory space. And Poser is not able to display the entire figure. Save what you have and restart the computer. That clears all the memory space that Windows mismanaging. You may find that when you open your saved file, the pants are still not all there. Just delete the pants figure and reload the pants figure. It should work. I have only noticed this on Windows 98.I run Windows 98 and that is how I fix the problem. If you are running Windows 2000 or Windows XP, I do not know what is going on. However, if load the file just after starting up the machine and it still does that, it is a different problem and I do not know what is going on. This should help. Willdial
![file_14529.jpg](https://live.cdn.renderosity.com/forum/threads/766881/file_14529.jpg)
Well, I wanted to use newts lowrise jeans, I loaded Vicky, then the pants, conformed them - but just a few parts are visible. No prob, I thought, and made vickys legs invisible - but the pants are still gone. Where are they?Thanks!
