Fri, Jan 10, 12:46 AM CST
Subject: Walk Designer and "leg shakes"
joke ( ) posted Tue, 02 July 2002 at 7:08 AM ยท edited Thu, 09 January 2025 at 5:25 PM
I am trying to create a slow motion run. I let walk designer create the run but if my runner follows a path in Poser the legs make sudden twitching moves. If I let the poser run without using the path there is no twitching. What gives?
brian71us ( ) posted Tue, 02 July 2002 at 9:39 AM
I was having similar problems just last week! Anyway, the problem is the yTran on the hip on some key frames. To fix the problem you have to use the Graph editor. Select the figure's Hip , then open the Graph editor (Window -> Graph). Select yTran in the drop down. Scroll to the key frames with leg wobble and drag the yTran value up just until the wobble goes away. Hope this helps! Brian
Norbert ( ) posted Tue, 02 July 2002 at 11:07 AM
Another thing to try, is adjusting the stride length and/or step height in the walk designer.
atom123 ( ) posted Tue, 02 July 2002 at 5:02 PM
there was another thread somewhere bout this not 2 far back. the person even got a response from cl. they claim that the walk designer only does 90% of the work. the other 10% falls on your hands...... i didnt like it either, but at least now i know its an "uncurable" disease........... raise the hips tho. thatll do it
atom123 ( ) posted Tue, 02 July 2002 at 5:17 PM
whoa, thats no good. lemme clear that up.......... after you "apply" your walk, youll need 2 edit frame by frame, and raise the hip in the frame where you see that little "crack addict step"......... lol, hope that helps........
