Mon, Jan 13, 4:15 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Is there a way to do this? A needed utility perhaps?
davo ( ) posted Fri, 25 February 2000 at 3:01 PM · edited Tue, 07 January 2025 at 8:40 PM
There may already be a utility for this, but if there isn't maybe someone can make one. Say I make a figure and get all of it joint parameters setup and things are fine, then I get to the last couple joints and find they don't bend correctly, or say I find some of those infamous back faces. Now I gotta replace those body parts and completely resave and re-joint the figure. Is there a utility or could someone work on one that would save all the body part names and joint parameters in their exact locations and assign them to a new figure (that has been corrected) with the same body part names and locations? Does this make sense? Or is there a program that already does that? This would be helpful to me and others I'm sure. davo
JeffH ( ) posted Fri, 25 February 2000 at 3:16 PM
Just save that Cr2 to the library and point it to the new version of your OBJ file. CR2Editor is good for changing the references. -JH
buckrogers ( ) posted Fri, 25 February 2000 at 3:55 PM
In each CR2 file there are TWO lines that point to the .OBJ file. Or, two for each model, if the .CR2 file contains more than one model.
bloodsong ( ) posted Fri, 25 February 2000 at 4:54 PM
heya; alternately, you can correct your obj and resave it with the same name; then delete the associated rsr's. reopen your cr2 library file, and it will read the new obj geometry.
davo ( ) posted Fri, 25 February 2000 at 5:12 PM
I'll have to experiment with all this, I know nothing about cr2 files and rsr's and the like. I appreciate all the help, I'll have to see how it goes. Davo ps Bloodsong, Delightfully Darla and Squishy are getting it on as we speak ;-)
Cage ( ) posted Fri, 25 February 2000 at 9:57 PM
Still, anything that would help simplify or automate the joint parameters would be a real blessing. Would such a utility be possible?
