Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 09 12:13 pm)
in some cases yes, Transpond, the makers of the dwarveb caves and several other large figure environments. use PLACE poses. They don't go so far as to put a figure at xyz c-ord and in a seat pose, but it can place the figure at XZY. Travler and transpond know how to change a file to do it, but they wouod be the ones to ask. they do hang round here but it is easier/faster to get then at runtimeDNA
You can do it by using a text editor to add a little bit of info to the pose file. The info you need to add corresponds to the settings of the x, y and z translation dials of "BODY". Just follow the same format as the rest of the pose file. It's not hard to work out once you have a look.
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Ajax is right. We purposely strip out the actual pose information as not to interfere with the user poses, and leave the xyz coodinates only. But with a little text editing you can retain both, if desired. For an example of the placement aspect of it, there are placement poses for the Prancing Pony Inn in my freestuff. I'd be happy to help you with any questions you may have in this thread, by IM, or in the RuntimeDNA forums.
What we do in life, echoes in eternity.
E-mail
| Renderosity
Homepage | Renderosity
Store | RDNA
Store
Perhaps I am misunderstanding the question? This is what pose files do. Just pose the character in a sitting position, at whatever location you want in the scene, and save the pose. When you apply the pose the character will come in at exactly the same position in the same pose. The only thing you have to watch out for is the position and rotations of the "BODY" element. This is important in two respects. 1). Poser does not save translations or rotations of the BODY element to a pose, so the x,y, and z translations and rotations of the BODY should be zero before you start posing the character, and you should position the character by translating the hip not the BODY. 2). When you apply the pose the translations and rotations of the BODY element should be zero, otherwise the pose translations will be added on top of those for the BODY.
If you don't want to manually zero the BODY's translations and rotations you can edit the pose file to do this automaticly, just add a body section, the format is like this:
version
number 4.01
thighLength 0.213434
//---Body section starts here---
actor BODY:2
channels
rotateY yrot
keys
k 0 0
//---More channels here---
translateZ ztran
keys
k 0 0
//---End of body section---
actor hip:2
channels
I have only shown the first and last channels above, but I hope you get the idea, you would have to include channels for each x.y,y,z, rotation and translation.
You could also implement the pose from a dial in the characters parameter pallet, via an ERC, but that is a little more complicated.
If you ever intend to tie morphs and gravity effects to a figure automatically, using the hip for physical location will mess this up. hip rotations should be used to orient the figure to gravity. hip trans - are useful in animations - if the IK are on. BODY rotations and trans are meant to locate a figure on stage. It looks as though the original programers expected pose files to save a generic body pose and PZ3 files to save the scene setup. They probably did not imagine a pose file being use the set a scene, so they left BODY channels out of a pose file. As has been said, it is easy to hack BODY rot/trans into a pose file - as long as there is a slot made for them. hip rotations and trans being used hapazardly is the rule. When running through a series of poses - using the front camera to view for example - the hip should remain at zero twist - as if skewered - and above and below wriggling and rotating back and front and/or side-side as the pose dictates. This is very rare. I have gravity JCM that are controlled by hip rotations, so they must be used reproducibly. The Poser 5 demo shows effects that may require that the figure be done in this way - to be able to tell where up and down are for the figure. If so, a whole lot of legacy poses will not be usable unless edited.
F'rinstance, if you want a figure to stand in the far left corner, and sitting down on a chair, or whatever other pose, is it possible to do that, and save that in your pose library for recall? Thanks
