Wed, Jan 1, 7:30 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Dec 30 1:55 am)
Check out the
Subject: Looking for a few good men.. err.. women... testers
Spanki ( ) posted Fri, 28 June 2002 at 5:54 AM ยท edited Sun, 29 December 2024 at 10:10 AM
I'm looking for a few people to test a new Windows app for me. The program is (currently) called 'S.T.O.M.P.' (Spanki's Third/Three-D Object Manipulation Program). It was originally written (a year or so ago) to re-generate normals to smooth seams between separate body segments and posted in free stuff as 'Body Shop'... As I've been doing some modeling recently, I needed some other tools, so I decided to re-write it and STOMP is the result. I currently use it to 'fix' .obj files for import to Wings3D, scale models (it only reads/writes .obj files) up/down, mirror/flip models (ie. create left boot, mirror it to make right boot), check texture seams, etc. It has a real-time OpenGL display with plenty of display options and plenty of .obj export options... I'm currently developing it on a Win98 machine and am looking for ME/Win2k/NT testers. Ideally, you'd either be a modeller yourself, or someone who often exports .obj files for import to other rendering apps (Bryce, etc). If interested, send e-mail to spanki@mindspring.com, but please keep in mind that I only need a few testers, so I may have already filled the slots ;). Several images to follow...
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Spanki ( ) posted Fri, 28 June 2002 at 5:56 AM
Wireframe rendering with lighting disabled...
Spanki ( ) posted Fri, 28 June 2002 at 5:57 AM
Flat shading, with textures disabled...
Spanki ( ) posted Fri, 28 June 2002 at 5:59 AM
Compressed both Normals and Texture Coords (compare stats in lower right) and mirrored on x-axis...
Spanki ( ) posted Fri, 28 June 2002 at 6:00 AM
Here's the material editor (the two smaller sample blocks are copy/paste slots)...
Spanki ( ) posted Fri, 28 June 2002 at 6:08 AM
One last one... this shows a sample before and after 'Smooth All' to fix visible seams on an old mesh I converted ages ago with 3D Exploration... The question marks on the 'after' image point to dark areas where very sharp polygon edges/corners are... my routine didn't fix those, but you can see that the other seams are gone.
Spanki ( ) posted Fri, 28 June 2002 at 6:25 AM
Just to clarify... this is NOT a 3d-modeller and it is NOT a 3d-file-format-conversion program (unless you count being able to read .obj files that some apps can't and spitting out ones that they can ;). It is (currently) just a tool to manipulate and view .obj files.
SAMS3D ( ) posted Fri, 28 June 2002 at 8:15 AM
It really looks interesting, lots of work on this software to. Sharen
GARYNH1 ( ) posted Mon, 08 July 2002 at 8:31 AM
I would like a copy if possible. I do a lot of exporting meshes around between various progs, and always endup with sharp creases etc. This looks like it could be usefull..
griffoso ( ) posted Tue, 09 July 2002 at 5:13 PM
I would love a copy of it looks like a real good program..
