Fri, Nov 22, 11:42 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Script for Animators
stewer ( ) posted Thu, 11 July 2002 at 7:22 AM · edited Fri, 22 November 2024 at 7:51 PM
Attached Link: http://keindesign.de/stefan/poser/
I think I saw someone requesting this: It's a little script that will prevent a figure's feet from going below the ground. It's also a nice example if you want to see how to use callbacks in Poser Python.
bushi ( ) posted Thu, 11 July 2002 at 12:24 PM
Thanks for sharing that stewer. And your right it is a nice little callback example. I think it's also shows a good use for the 'try: ... except:' structure. I find I use this a lot especially when dealing with tkInter.
saxon ( ) posted Sun, 21 July 2002 at 2:55 AM
Oh that's brilliant, thanks Stewer...
