I have the headset.obj reworked to accept a texture map. I opened the file with Ray Dream and saved it out again. Then I opened it in UVMapper. What exactly do you want to do with the textures on this? What parts do you want to apply textures to, and what parts will changing the color be enough for. The way I have it right now, you can take it ingo poser and color each part. It would have been much easier if you would have named the parts like right wing, left wing, front jewel, jewel base, etc... I will keep working on this.
I have this done. Have a look at the image I posted in the following thread. http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=78794
Attached Link: http://www.cybergate-corp.ch/webdesig/poser3/headset.OBJ
I need definitly your help. Since more than 25 hours i am working/testing some methodes to create a texture-map for the face-mask and the headset. Nothing works, i had tested with Mapping-Magician UV-Mapper but nothing works. Sometimes the texture is applyed in the preview-mode but not by the render and sometimes the created template does not apply. I give up and hope someone can do this job for me. If someone do this job and send the template to me (if possible a short-description how you had done it), i will create the template for the Face-Mask and upload the props to the Free-Stuff-Section. You find the Object-File at the Link below. Please, please help and send a texture-map to sharkey@cybergate-corp.ch Hopefully SHARKEY from Switzerland
