Fri, Nov 15, 1:18 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: HELP: polygon reduction
rickylwk ( ) posted Mon, 03 May 1999 at 1:14 PM · edited Thu, 14 November 2024 at 11:30 PM
I exported a character from poser 3 to other 3d app like truespace, 3dsmax, lightwave.... and perform "polygon reduction" on it, the model changes to a polygon-breaking monster and the textures are torn......... please help me..........
GaryS ( ) posted Sat, 08 May 1999 at 6:40 AM
I am assuming that the tearing is taking place when you bring the "polygon-reduced" model back into Poser. I know that the texture maps are strongly tied to the polygons that define the object. You will need to generate a new UV map (UVmapper utility can do this for you). I believe that you will need to create a new geometery entry in Poser so that Poser knows what part goes with each set of polygons. I cann't help much in this department. I do know that reducing the polygon count is a lot like making a new character. There should be some tutorials around that describe the process of bringing a new Poser model to life. Good luck Gary
